Close excel workbook
Hi All. So This is quite a common topic but no one seems to have an answer of yet. The excel file I am creating keeps opening which I dont want it to do. Is there a node that can either keep it closed or force it to close afterwards?
@technitutors , hi
seems to be a older topic
yes but no ones solved it, I tried the node within that topic doesnt work
okay got it with the passthrough node
@technitutors ,
what do you have in your PythonScript? whats your input?
the input is just some excel script I found on the internet. The PythonScript is the one I found on that other topic you sent
@technitutors Just to add to the solution here I am pasting the code which is workable,
from System.IO import Directory
import re
import time
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import subprocess
import os
import errno
import csv
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
from Microsoft.Office.Interop.Excel import ApplicationClass
from System.Runtime.InteropServices import Marshal
true_false = IN[0]
def excel_close(_bool):
    if _bool:
        xlApp = Marshal.GetActiveObject("Excel.Application")
        xlApp.Visible = True
        xlApp.DisplayAlerts = False
        xlApp.Workbooks.Close()
        xlApp.Quit()
        Check =  "Success"
        Check = "Set the boolean to True"
    return Check
OUT = excel_close(true_false)
