Dear all. I need help. I want to create a Branch Duct connect to Flexible Duct. Thank you
Flex connection AirTerminal_Test.dyn (40.4 KB)
¨Hi @WSAMAN probably something here
Revit_m7jdLLfMRs
Thank you very much. Best Regards
Dear k. Søren Villadsen. I don’t know what to do to make the tap duct run Auto. Thank you.
Hi @WSAMAN looks like element binding if you will run one by one, try run from player and set the side with the normal node…if you will run at multiple probably something here…hope i understand :wink:
Revit_HeSBJmRGIm
Thanks very much. Best Regards.
Dear K. Søren Villadsen. In the case where the Main Duct is Duct Rectangular, can we have the Branch Duct be Duct Round? Thank you. Best Regards.
yeah absolutely, i guess :wink: try with round duct by line :wink: but let us close it here…:wink: if you have other thing …please create a new topic :wink: cheers
Thank you so much. Best. Regards.
Hello mate, this is excellent work. Can I get the dyn file for this? Cheers!
dont have it anymore…and its already showed…try you can follow the image or create a new topic and show all you have tried so far…
Thank you for the response! I’m having a hard time following the script because I can’t seem to find the packages for the nodes you used. I’m pretty new to dynamo in general so I’m tinkering around. Is there any way to determine the packages used based off the name of the node alone? Cheers!
arhh yah…guess it was OpenMep and MePover and probably some genius loci…great packages for mep…open mep can be found here, the other just install from package manager
I’ll take note of these packages. Big help. Thank you, mate!
and remember instal dynamoironpython package 2.7 version 2.5 as well. for let MePover work in 2023-2024
