I would like to get the geometry of an existing solid in Civil3D so that i can check if it intersects with a generated solid within dynamo. I use the DataShapes SelectAutoCadObjects_Data node to select the element. After selection the result is a System.__ComObject anyone knows how the get the geometry of this kind of class?
UI works fine!
Same result in:
Civil 2020 Beta Dynamo 2.4.1.2161 Data-Shapes 2021.2.9
Civil 2021.0.1(hotfix) Dynamo 2.5.2.86 Data-Shapes 2021.2.9
Hi @GinoKoolman
You need to convert ComObject to Autodesk.AutoCAD.DynamoNodes.Object which can be done with few lines of python:
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('Civil3DNodes')
clr.AddReference('AutoCADNodes')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
#Import References from dynamo
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
editor = adoc.Editor
def Get_Civil_Object(COMObject):
if not isinstance(COMObject,list):
COMObject = [COMObject]
output,handle = [],[]
with adoc.LockDocument():
with adoc.Database as db:
for c in COMObject:
handle.append(str(c.Handle))
t.Commit()
for h in handle:
output.append(SelectionByQuery.GetObjectByObjectHandle(h))
return output
OUT = Get_Civil_Object(IN[0])
Great, thanks!
I seem to be getting a ModuleNotFoundError. Could someone point me in the right direction? Thank you
On Which civil3d version?
Civil3D 2023
I have added the documents I am using to test it.
Select_civil_UI.dyn (19.1 KB)
Testdwg.dwg (426.1 KB)
Add flatten node before python node.
Awesome! It works, thank you
You’re welcome!
