DataShape Multipleinputform++ split display
Does anyone know any way to split the output window in Multipleinputform++ node?
I am displaying summary results using this node and output window gets quite long. Is there any way to split it after one point?
Manually in the graph. Split the data and feed it into 2 separate form nodes (though I think they have to run one after the other instead of simultaneously).
Manually in graph?
If i separate in two nodes, it will run one after another not simultaneously.
If you are talking to have them side by side the answer is no.
But you should have scroll bars
so if I will have a longer display than screen height I’ll have a scroll bar on side?
Exact, unless you’ve set it to false in the ++ node
