Hi there,
I’m creating a script with a UI using the nodes from Data-Shapes package.
The script contains 2 forms: the second form shall appear if a condition is matched on the inputs the user entered in form 2. If the condition is met, a python script executed and get a list of strings that I want to pass to form 2.
I managed to get all this working but the second form shows up with no values. If I close it, it will pop up again a second time correctly populated.
I tried to use a passthrough node between the first form and the second in other to wait for the readiness of data preparation for form 2 but the results are the same.
I fed passthrough with my values to populate form 2 at both inputs.
What am I missing?
Can’t add the dynamo graph at the moment because I’m not at my desk but if need be I can provide for it tomorrow.
Thank you.
