d-vader
November 11, 2022, 9:52pm
1
So the problem is that Data-shapes can see no rooms at all, when Revit sees them(you can see archive with the screen of a problem below)
https://drive.google.com/drive/folders/1jbRCLkSuHfJ5OVxS3powcnz8NPOcW4Zy?usp=sharing
I’ve downloaded Data-shapes in the right folder, repeated this on different computers and with different models, but always got same result, so what’s the matter here?
Likely the graph leading up to the UI trigger is off - post a screenshot of the content leading to that UI, with data previews expanded.
One other option is that you’re looking at a cloud path which isn’t real in that the files aren’t yet synced to the disc, and therefore don’t exist.
PS: bumped up your trust level so you don’t have to use google drive.
