I am trying to use UI.Listview Data to select a level. The dialog box pops up, however when I select set values Revit crashes. I have tried re-installing multiple versions of the package and I’m using Dynamo 2.0.1.
Can you close Revit, open a new instance of Revit, open a blank project, open the graph with just the UI++ content which triggers the error, run it, let Revit crash, a d then provide the Revit journals and Dynamo log files for review?
