Search for online repair on the forums and you’ll find the answer 100 times over.
That or verify your data is a 2d matrix, and the other inputs are all valid.
Not Working:(
Did you do an online repair? If so great!
Now share your warning message.
Your filepath should contain the full filename, including “.xlsx”. It seems like the File Path node is returning a directory somehow.
Verify the online repair, or try using the open xml excel nodes.
Also try pathing to an excel file on your desktop. Onedrive has a tendency to cause issues when writing out.
did you test ExcelReader Package? I think it would be usefull. Otherwise csv interface is an alternative solution.
