I created the 2 lofts in dynamo and i was wondering if their was a way to erase the overlap in the photo below where the 2 lofts intersect.
Since only edges intersect, you could try to extract the perimeters of your lofts at top, use Curve.ExtrudeAsSolid + Geometry.Intersect to create a volume at the intersection location, and then use that volume to cut the surfaces with a Surface.SubtractFrom node.
Create a Solid by union, explode and then remove the top of the surface by z elevation with a boolean mask
Thank you so much
