Hi do you see the node in the library ? if so then try change the node from library…know thats an issue when just created…try and see if that help
hey,no I can’t see it in the library ![]()
allright sound as another issue then…try rebuld the node again…maybe…do you see the defination in the folder ??
So what if you save your definition in the ‘standard’ folder?
C:\Users\USERNAME\AppData\Roaming\Dynamo\Dynamo Revit\3.3\definitions
