Guys,
I’m fiddling with curtain walls, the curves atm. which I want to dimension in the end.
To my knowledge curtain walls are actually
- a collection of grids,
- the grids have mullions assigned
So if I want to obtain the geometric references of the curtain wall (the outline):
- get the bounding box of a curtain wall since the curtain wall itself has no geometry
- neglect the y-value
- min, max point will allow me to define the outline ???
Python/api gives me boundingbox too as only option?
Curtain walls have a location line and a height as well. Might be better to work with those and extrude the location line by the height.
Don’t think that will work, I need to get a list of ReferenceArrays in order to place some dimensions in the end.
NewLinearDimension Method (View, Line, ReferenceArray, DimensionType)
Does anyone have a clue how to get a list of ReferenceArray’s??
pfff how annoying. I can’t figure it out.
How do I get to the reference of a curtain wall?
from Revit.Elements import *
clr.AddReference('RevitAPI')
#gc = UnwrapElement(IN[0]).GeometryCurve
for l in cw:
t = l.CurtainGrid.NumULines
u = l.get_Geometry
#h = l.get_Geometry.Faces
#g = l.CurtainGrid.NumVLines
OUT = t,u
u outputs Ironpython.Runtime.Types.BuiltinFunction … which is good I guess? Is that how the references are retrieved?
