Curtain walls- Automate section views.
There are many scripts to automate section views of elements but none works with curtain walls. Anyone knows how?
Create Sections by selection.dyn (37.3 KB)
Try this method:
Hi all,
Did something in my downtime while waiting for a train which I thought I’d share.
[Capture]
It takes a selected wall element (or any other curve based family really), and inputs for the percent of the length where you want to cut the element; an offset from the element, the depth of view cut, add if you want it flipped not and gives you a section which is perpendicular to the element, including the “outlines” of the element as detail lines to allow for snapping.
Great for those curv…
My guess is that curtain walls aren’t going to be any different than basic walls.
