Ctrl+B
Hello community, these days Dynamo is having a lot of problems.The Geometry icon has disappeared and I can’t activate it.Any help would be appreciated, thank you!
Which version of Dynamo? Is this core or an integration?
Can you post your Dynamo log and if it’s an integration the associated log therefor (i.e. your Revit journal)?
Dynamo Integration
Ok - so the latest and greatest. Can you share the logs too?
dynamoLog_56224007-e51d-4801-bb93-5ada43dfd9de.txt (18.3 KB)
Well the log states it doesn’t have the required resources, so that might be related…
This means it wasn’t installed properly right?
Not necessarily. Could be a windows update. Could be a driver. Could be… well anything.
hello, no it was working but it suddenly disappeared.
Spot on, Jacob. It’s usually the first thing to break when something else updates. For anyone else stuck on this, it’s worth checking if another app (like a screen recorder or a GPU utility) has ‘hijacked’ the Ctrl+B shortcut globally. Sometimes just clicking the background navigation icon manually once seems to ‘reset’ the focus so the shortcut starts working again.
