I’m trying to just create a filled region with one circle. I need to mark one node in my plan and wanted to do it like this, but it seems like a circle is not allowed to use as the curve for the filled region? Does someone know how I need to change the circle so it works for the filled region?
Thanks!
Hello @klara.steinMZ7FJ …try convert your circle to polycurve…poly curve by joined curves…
Thank you, but it did not work, I got a different warning now.
Try someting could probably work…
@sovitek gave you a solution but the reason is because a boundary is represented by boundary curves. There must be more than one. Even a list of a singular enclosed curve does not work.
Yeps Nick thats why
@klara.steinMZ7FJ dont think you need joincurves…
this one worked, thank you!!
