based on this topic: Create multiple family instances with different types
I was trying to create a wall that offsets a curve where the families will be placed on this case an IT cabinet (that’s a riser wall btw). I’ve created the script without UI and it’s working well with some input manipulation. I tried to make a UI just to streamline the workflow as I’m working on multiple files. But as you can see on the following images, the FamilyInstance.ByPoint node only makes a single element even though I can see the points that was created.
also the dynamo graph:
xxxWallCreationFamilyInstance.dyn (156.5 KB)
(Don’t pay attention to the wall I’ve used - i know it is clashing on the cabinet
Thanks!
