Dimension to face reference and element
I’m trying to combine the two methods of automatically dimension in Dynamo. I can dimension element to element using “Dimension.By.Elements” node. And I can dimension face to face using this python script
Is there a way to combine the two, i.e. Dimension to a face and an element.
Thanks in advance
@Thomas_Mahon or @Mostafa_El_Ayoubi
@Konrad_K_Sobon
Hi @Shay_Egan
You should copy your formatted code using this button :
Hi Mostafa,
Thanks for your reply
Here is the code that works for Face to Face dimensioning
from Revit.Elements import *
clr.AddReference('RevitAPI')
dataEnteringNode = IN
line = UnwrapElement(IN[0]).GeometryCurve
elements=(IN[1])
dim = 0
elementsRef = ReferenceArray()
opt=Options()
opt.ComputeReferences=True
opt.IncludeNonVisibleObjects=True
opt.View=doc.ActiveView
for element in elements:
	elementsRef.Append(element)
dim=doc.Create.NewDimension(doc.ActiveView, line, elementsRef)
(True)
OUT = dim
And here is the one I am working on now to try and dimension from a floor edge to a grid line
grid = UnwrapElement(IN[1])
elements=(IN[2])
dim = 0
geomopt=Options()
geomopt.ComputeReferences=True
geomopt.IncludeNonVisibleObjects=True
geomopt.View=doc.ActiveView
refg = []
for i in grid:
	r = i.get_geometry(geomopt)
	[refg.append(j.Reference) for j in r if str(j).contains('line')
for j in elements:
dim = []
for i,j,k in zip(refg,elementsRef,IN[0]):
	refarr = ReferenceArray()
	refarr.Clear()
	refarr.Append(i)
	refarr.Append(J)
	dim.append(doc.Create.NewDimension(doc.ActiveView,k.ToRevitType(),refarr))
TransactionManager.Instance.TransactionTaskDone();
OUT = dim
It is actually a variant of something you posted on another discussion
Any help from you at all would be greatly appreciated
Could you please paste your code as preformatted text like @Mostafa_El_Ayoubi mentioned above? It will be easier for users to help troubleshoot for you without having to indent all the code. :slight_smile: also what is the error that is appearing when you run it?
I think he doesn’t know how to do that but i had edit his code. Looks good now :slight_smile:
Thank you @Kulkul. I’m new to posting here.
Essentially I know how to dimension from element to element, for example, gridline to the centre of a wall, column etc. I also have some python code that will dimension from the face of a wall to a face of wall. But now I’m trying to figure out how to tweak this python code to dimension from a gridline to a face of a wall. Does that make sense?
