I want creat dimension of rebar.
Script example:
clr.AddReference('RevitAPI')
clr.AddReference("System")
rebar = UnwrapElement(IN[0])
view = doc.ActiveView
def creatdimension(view,linedb,refs):
references = ReferenceArray()
for ref in refs:
references.Append(ref)
dim = doc.Create.NewDimension(view,linedb,references)
return dim
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
for line in rebar.get_Geometry(opt).GetEnumerator():
lineout = line
ref1 = lineout.GetEndPointReference(0)
ref2 = lineout.GetEndPointReference(1)
linedim = rebar.GetCenterlineCurves(True,True,True,MultiplanarOption.IncludeOnlyPlanarCurves,0)
for l in linedim:
linedim1 = l
shitf = UnitUtils.ConvertToInternalUnits(-200, DisplayUnitType.DUT_MILLIMETERS)
vec = shitf*XYZ(0,0,1)
transform = Transform.CreateTranslation(vec)
linedim2 = linedim1.CreateTransformed(transform)
references.Append(ref1)
references.Append(ref2)
dim = doc.Create.NewDimension(view,linedim2,references)
OUT = dim
File “”, line 55, in
Exception: The references are not geometric references.
Parameter name: references
