Creating Alignment in Revit Generic Adaptive from extracted Civil 3D alignment points
Hi there,
My name is Rod,
I would like to request for your collaboration to come up with the solution.
I have an alignment that I created in Civil 3D.
I would like to bring it in Revit to work with some component. Using that Alignment as a reference path.
How can I create the exact alignment from Civil 3D data to Revit. Including its elevation.
It is possible to use the Generic Adaptive. But I would like to know from brilliant minds herein on how we can approach this in a awesome way.
Cheers,
Rod
Hi @Rod.D.Lecetivo,
Have you taken a look at the CivilConnection package for Revit?
Zachri Jensen,
Hi, I thank you for your response. I will look into it. Thank you very much for your advise.
Hi, @zachri.jensen
I looked into it. is there a way you can guide me on how to make one out of the civilconnection.
I very much appreciate your kindness.
Take a look at the documentation here and see if it helps.
I was overwhelmed with the idea and information. Need to catch up.
I found a solution.
Connecting Civil 3D to Revit.
