Hey everyone, I want to create a sloped floor and I have tried a dynamo script by @Kulkul but for some reason it doesn’t work for me.
Try setting the Boolean to false.
I’ve tried doing that but it’s not working
On second look at that node, it looks like the purpose is to add point, not adjust point. The new points aren’t on the surface, see if this helps. https://landarchbim.files.wordpress.com/2016/05/matchfloor_def2.png
@Yousra May be you should add list.flatten node before geometry.translate
So now you are feeding a flattened list for the geometry translation.
Hope that helps. !
