Hello!
I am trying to create a Floor Object in Revit using Dynamo and I am struggle to create it on an incline. Where I use the Floor.ByOutlineTypeAndLevel node, the geometry I give the node, whether it is points or curves needs to be create a closed horizontal loop. I have found a somewhat OK workaround by adding points to the floor using “Floor.AddPoint”, however there is a separate issue where if I change the input geometry, the floor will flatten back down.
Any help is appreciated!
