Hi all, although this exact topic was solved back in October last year, I couldn’t use the answer mentioned there, I posted again there, but I had no answer. I assume it’s because it was long ago. Anyways, this is the problem:
I’m using this code “CreateFamilyIstance” to create a simple column in XYZ(0,0,0). In the previous solved topic, they mentioned that you can change python engine to Python 2 or so, but in my case I don’t have that option.
Even if I could have the possibility of changing the engine, or use dynamo nodes, I’d rather not to do it. Mainly because this is not a code only for me, it’s for my company and many of them don’t know how to use Dynamo Player, and they don’t know how to change the engine in case that they need it. So I will create a tool tab for revit so they just need to click on the button (once the entire code is finished)
I assume there must be a way to do it only with python in Revit 2023. Thanks
chatGPT didn’t help because its training data base comes until 2021 only.
Thank you
