HI… I am trying to run a python script in Dynamo, I am facing trouble in running it. The error shows as PYTHON ENGINE COULDN’T FOUND
Hi @Arunkumar.Palanisamy,
If you are in Dynamo 2.13, you need to install the IronPython2.7 package.
Only the CPython3 engine is installed by default.
Hi @Alban_de_Chasteigner ,
i have installed that IronPython 2.7 version but still facing the same error.
In Revit 2022, IronPython 2.7 is OOTB (include with Dynamo) which version did you install?
Hi @Draxl_Andreas,
I have the same issue as @Arunkumar.Palanisamy. What do you mean by import the library? Which library and where to import it?
Thanks in advance!
for running you scripts you need the correct framing
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
i do always copy/paste this inviroment.
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
OUT = element
Oh sorry, I didn’t mentioned that I’m using it under Civil 3D, but I realized what you meant. I try to find for a C3D template.
