I am using Iron python for Revit 2022 and I wish to use same Iron python for Revit 2023 to Revit 2025, But Currently I am not able to use iron python in my Dynamo, In preferences also iron python is not available and selecting a node and right click and In python Engine also iron python option is not available, I shows only Cpython. Kindly help me to use iron python in dynamo and how I can bring Iron python in Dynamo
You will need to install the IronPython2.7 custom package to support the engine in higher builds unfortunately.
Typically the 2.5 version is the highest build you should install for Dynamo 2.x builds.
Thank you for the response, I have Installed Iron python 2.7 and its works for Revit 2024 and its not working for Revit 2023. In Revit 2023 still I am not able to see Ironpython also for Revit 2025
Look at your Dynamo version (in the about item in the Dynamo menu) and then read the specific details for the IronPython2 package before you install a version. Note that if you installed the wrong version you will need to restart Revit after starting the uninstall process.
hi,
for info
