Create workset
HI,
Sorry for re-open this Topic, but i m truble with workset create package, i’m following the (easy) instruction, but the node return a null value.
There are some limitations about the revit version or something like that?
thanks in advance
Hi @alessandro_mambrin
Could you let us know what versions your using:
  • Revit
  • Dynamo
Hi @Kulkul ,
revit 2015 and Dynamo 1.2.1
You need to Update to 2015 R2 Version in order to use create workset. That function is available in 2015 R2 or higher.
Ok
thanks @Kulkul .
:slight_smile:
