Hi John,
I was trying to create workset using your “Workset.Create” node by some reason its giving me null. Below is the Screenshot.
Hi John,
Try running manual and exiting the workset window in revit
Thanks John,
For replying. I tried to Run Manual still i get null values. I am using Revit 2015. I am trying to update to R2 and see the difference.
Yes R2 is required. Autodesk added this functionality at that release.
John, I’m trying to set the workset of wall elements. I can’t seem to get it to work, any ideas? I’m using rhythm “element set parameterByName(CaSe iNsensitive)” and getting null
You need to send it a workset id (integer)
Thanks for the response. It seems to work but it only moves one element to the correct workset. Any ideas? I’m testing it on walls.
On the setparameter node set the lacing to longest (right click on node toggle to longest) and it will do it for all elements selected.
Thanks, that was what I was missing. Thanks for your help. Such a great tool but I’m still learning.
No problem. That’s why we’re all here!
as long as you’re having fun!
I can’t stop, I should be doing other work…
John - I’m having issues with the workset.create node.
I’m running Revit 2016 R2 - is it compatible with this version?
Revit 2015 R2? It should work on everything after that.
@john_pierson is this package still working for Revit 2019.2 Dyanamo 1.3.4
Rhythm is still compatible with 1.3.4. However, workset.Create was retired some
Time ago as part of the effort to move to ZeroTouch. Archilab has a replacement you should use.
A manner to code Dynamo nodes in C#. ![]()
Info about ZeroTouch
To summarize why I made this move: (from my Github readme)
With Dynamo 2.0 comes a fundamental file format change that makes anything that is a DYF or DYN (the filetypes that Dynamo uses) not backward compatible. This forced me to choose between two options. Option 1: Have 2 versions of Rhythm for each major version of Dynamo, eg. “Rhythm for Dynamo 1.x” and “Rhythm for Dynamo 2.x”. Option2: Continue my long term goals of migrating Rhythm to be fully “Zero Touch” c# code. I went with option 2 as it provides a more stable product and further compatibility.
