Hi All,
Just only finding time to finally post this. Create worksets and compare if workset exist already. Just simple graph that may come handy to whoever is looking for this.
Packages used:
Bakery
Data-Shapes
Rhythm
Core Nodes
Tested on Revit 2015 and Revit 2016
Dyno Browser - you need to download this is not a package
Dynamo
The video showing how this put together is located in
I did not test this yet with Dynamo Player but I am sure it will be ok
The DYN is here
Create Worksets UI.dyn (30.6 KB)
And the small image for testing
You can also downgrade this to use the Dynamo Interface just remove few nodes and resave it as Classic.
There are a number of ways to do this but personally I like the UI++ version. Many thanks to Data-Shapes @Mostafa_El_Ayoubi for sharing his knowledge to better Revit and Dynamo.
This is my SHARE on Sharing is Caring…without this community I wont be able to learn Dynamo faster than I ever expected
NEXT to come…Creating PDF’s with Customized Filenaming using Ghostscript.
Thanks…
