Hi All,
I have a question to how to create thickness from the Rhino surface in Revit. for information i already convert the rhino into Revit but the points its just surface and i need to add thickness through Dynamo to it. Is there any one can advise?
@a.shamy
These are builtin nodes, no need for installing a package.
Marcel
yes its seems working but how i will return back the updated surfaces with thickness in Revit again
@a.shamy
spring nodes has a node for that.
Marcel
Hi Marcel and all,
As of now what i did i already convert the rhino surface into Revit by Dynamo as an independent family in the below snapshot, then i need the update this Revit family geometry with adding the parameter of thickness for those family to be joined directly the same like this family.
The point that for these surface i have flat surface and curved surface and both of them cant used the same node of thickness.
sorry for keep my reply too long but if there any adivse please share
