Create solid from surfaces
Støttemur.xlsx (10.9 KB)
Støttemur.dyn (89.7 KB)
HI
Iam trying to make a script to create a retaining wall( gonna make alot of these in the near future) Iam very close, but Iam missing the last bit:
Create a solid from the surfaces? I have tried a couple of approaches but none of them seems to get me where I want.
Anyone have any idea?
Brage
Hei Brage,
have you tried Solid.ByJoinedSurfaces?
Hi Einar,
Yes I have tried that node got an error message, I suspect that the node wont work since the surfaces is not closed(its an opening on both ends)…?
Sweeping a profile would perhaps be much easier:
Hi
Its different heights at the wall
You could use different profiles as indicated as a link in the post I mentioned.
But if you need to stick to your method, you could select all start and end points of your curves and try to create surfaces out of that. But I have tried it and I encountered difficulties. This is why I suggested another approach. Someone else could also have another solution in mind…
okey, thanks for the responds, will give it a try
A quick workaround to easily create the end surfaces, if you don’t need to repeat it too often, would be to use Select Edges + PolyCurve.ByJoinedCurves + Surface.ByPatch
