Hi all. I am new to the dynamo but I do need your guys some guidance.
I have created the create the sheet from excel in dynamo and work successfully.
I have a question that extends in regard create sheet. I would need to sort the sheets based on the sheet category and sheet folder. Is there any way I can do that? See screencap below
I am working on creating folders in the sheet view and I see you need to add the ‘setparameterbyname’ node. I’m still fairliy new and I am having trouble figuring out where to place the node.
I have brought in all my sheets via tabs in excel. I then split them up so I could isolate the different sheets for the different sub folders.
Below is a screenshot. Any help would be appreciated.
