Hello ,
im trying to create rooms with several patametres from excel sheet , it works well with room naumber and name , when i try to add more parametres it shows this message above the node
Element.SetParameterByName operation failed.
The call is ambiguous between the following methods or properties: ‘Revit.Elements.InternalUtilities.ElementUtils.SetParameterValue(Autodesk.Revit.DB.Parameter, Revit.Elements.Element)’ and ‘Revit.Elements.InternalUtilities.ElementUtils.SetParameterValue( Autodesk.Revit.DB.Parameter, string)’
but in the other hand the data is well filled in room’s parametres
thank you
