Create project parameter node not working
I’m trying to add a shared parameter as a project parameter - and I can’t see why it’s not working. Can anyone point me in the right direction?
You might have to use the Select Parameter Type node
Hi @cjg63C47,
Are you sure the “_Egan” parameter is a text parameter?
Also, the parameter group will probably fail you aswell, since its looking for the string representation of the BuiltInParameterGroup. I don’t think this is very logical for new users (forgive me for the assumption), but a way to get around it, is to use a node like the ParameterGroup list from the Data-Shapes package, which will give you a list with all the BuiltInParameterGroups:
PG_CONSTRAINT" instead of “CONSTRAINTS”
“_Egan” is the name of the group in my shared parameter file, so this is correct.
The solution is that I wan’t using the right name for BuiltInParameterGroup. I have now used “PG_TEXT” and it works! This is certainly not intuitive for a new Dynamo user like me. I never would have figured it out on my own. I have much to learn.
Thank you!
MartinSpence alluded to this as well. Problem solved. Thank you!
