Hei Dynamo experts, I need help with a little project of mine. I’m trying to create a share parameter in Revit. I wrote this one:
Check if the groupName group exists in your shared parameter file.
Also this is a “one time” node, you run it once, parameters gonna be created in SP file and under Project Parameters as well.
@daninet Thanks for reply I have a group named as Test in my SP. I also tried this with different group names but didn’t work either.
Also Dynamo crash after every run.
