Hiii Everyone,
I’m trying to create a curtain panels with mullions that should connect between lower slab edge and upper slab edge.
The first issue is that the two slab edges are not the same in their paths as shown in image below
The second issue is that if i create points along the lower edges and the same for the upper edges then trying to connect between them to create a surface, i found that this surface is not a planar surface and this is because the lower and upper slab edges have no the same path.
the shots from design should be like this (with a planar panel and a shifting between panels out of plane
graph and Revit model (2021) are attached
Test.rvt (1.6 MB)
NBS Trial3.dyn (298.0 KB)My problem is that I CAN’T CREATE A Planar Surface , Any Help Please ?
