Hi All,
I am cracking my head around coming up with a solution to eliminate duplicate pedestals under raised access flooring panels. The basic requirement is to be able to use curtain systems or divided mass surface to generate raised access flooring - which is a an adaptive rectangular family. But my problem is that the pedestals would be repeated with each panel whereas the ideal case would be to have one pedestal per crossing. Similary for stringers shared by each of the sides of the panels. Just trying to see if I can develop a template to drive the process of raised access floor modeling for a sub-contractor.
One solution I was thinking of is, to use glazed roofing category and get the grid right with generic panels and use a dynamo script to distribute pedestal families at intersection nodes of the curtain/grid system.
Any direction or help is appreciated.
