Create Multiple MEP system By using Excel sheet
Hi everyone,
when I’m Clicking on run button only half script runs, but on second attempt it runs well,
please try & tell me why?
(screenshot is of first Run)
123.xlsx (11.9 KB)
Create Duct system from Excel.dyn (47.5 KB)
HI @vishalghuge2500 ,
You’re applying the Transaction.End node in the wrong place, you should use it after the FamilyType.Duplicate nodes. Then using a PassThrough node make sure those nodes are executed first before writing the parameter-values. See the example below for reference if you find it hard to follow:
Hi @Daan
I tried but its not working, may be still I’m doing something wrong,
Hi @vishalghuge2500 try as here…
Hi @sovitek
thanks for your reply
With this nodes Arrangement system are getting created but Abbreviation parameter value are missing.
and on second run click its showing errors
Create Duct system from Excel1.dyn (46.1 KB)
123.xlsx (11.8 KB)
Hi …strange works fine here…second time you run it will fail, because then the new meptype already exist…and need unique names for run again…
