Create Multiple Catchment Labels
Continuing the discussion from Hatch centroid definition:
@KirkWM here’s some Python code if you want to create actual Catchment labels instead of MText.
CatchmentLabels
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.Civil.DatabaseServices.Styles import *
civdoc = CivilApplication.ActiveDocument
catchment = IN[0]
labelStyleName = IN[1]
def create_catchment_label(catchment,styleName):
	global adoc
	global civdoc
	output = []
	if not isinstance(catchment, list):
		catchment = [catchment]
	with adoc.LockDocument():
	    with adoc.Database as db:
				for c in catchment:
					catchmentId = c.InternalObjectId
					obj = t.GetObject(catchmentId, OpenMode.ForRead)
					if isinstance(obj, Catchment):
						labelStyleId = civdoc.Styles.LabelStyles.CatchmentLabelStyles.AreaLabelStyles[styleName]
						label = CatchmentLabel.Create(catchmentId,labelStyleId)
						output.append(t.GetObject(label,OpenMode.ForRead))
				t.Commit()
	return output
OUT = create_catchment_label(IN[0],IN[1])
This is brilliant! Worked perfectly, thanks a bunch.
Attaching dyn for the next person.Catchment labels python v1.dyn (11.4 KB)
@KirkWM check out Camber, my new package for Civil 3D. There are some nodes for creating Catchment labels.
