Create IFC File without REVIT (Dynamo Sandbox)
We don’t work with Autocad and Revit in my company but we use DWG from our client and import them in Vertex Software.
I want to know if it’s possible to create and export geometry as IFC created from DWG block origin with dynamo ? Is it possible to extract origin of block in DWG directly from Dynamo Sandbox ?
@romain1993
i have no idea,
but in that case i would dive deep into Blender and Blender BIM
https://blenderbim.org/
@romain1993 ,
regarding CAD Blocks check out topics like this
I recommend you first check that the DWGs are suitable to generate an IFC with the data you need.
i.e. are the walls objects, or just parallel lines?
