i had the same issue that @Soren_Karlsen talk about in his Topic which is
"So i’m trying to make a floor finish automaticly from the rooms, which is working fine until i place a column in the rooms.
I managede to get all the rooms outline and the columns outlines with the polycurves. The problem is that it know treats the coloumns as a room and creates a floor in the columns outline insted, and mess up the order in the list so the the floor type is not matching the rooms “floor finish”
I know theres been some other posts similar to this, and the “Hostedflooropening.bycurves” might be the solution, but i dont quite seem to get it!
So to sum up, what i want to do is:
- Remove the columns from my list of curves so it only contains the rooms.
- take the columns outlines at make at void from them that cuts away the floor that is in the column area
so i create a script but i fail to make one floor not two floor
