Hi all, i have a design like below combined by hundred of panels and going to send the dimension data of each panel to the manufacturer. Is it possible to automate this process by Dynamo?
Further image for reference, the look of a single panel.
Yes it’s possible. Take a stab at it and see where you get. As a reference check the thread here:
Jacob, that node only available in Dynamo 1.3.
I’m curious - The manifacturer can use DWG or some other kind of CAD file to load into CNC Router, Laser Cuutter or another machine - I suppose there is no need of dimensions - of course if they will use CNC Router,Laser Cutter or other computer guided machine.
