Hi All, newbie question coming in again.
I have had luck exporting data from two schedules to excel, however I want to achieve the following:
Final output; a schedule which takes nett floor area of each level (room schedule) and works out the percentage of glazing for that level based off of values taken from a window schedule with calculated parameter for window area.
Instead of exporting the two schedules’ data to excel, I would like to use Dynamo to sort and list each nett floor area per level with each total window area per level in one schedule, from which I can introduce a calculated parameter to work out the percentage relationship between the two values. Is there an easy way to do this with Dynamo?
For reference, a dynamo file is attached based off of instructions followed from this video: https://youtu.be/Lb3zs2HOo34?si=ohEG3CFRj1SH3db6
This works to export any selected schedules into excel. It would be great to adapt this such that I could still select the desired schedules, but create a new combined information schedule in revit.
Any assistance would be greatly valued! Thank you.
fen-nett floor test.dyn (35.8 KB)
