Yes
did anyone get this script to work? Will they share how they did it or or the script.
got it working… Thanks
Maybe a little late but was having a lot of issues with the custom node so I just adjusted the inputs a bit and copied it into python script in dynamo. Didn’t have any issues after that ever and it was used often. On dynamo 2.6.1. Hope it will help someone.
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
elt = []
for i in IN[0]:
elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[1]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=List[ElementId](elt)
viewlist=[]
schedlist=[]
sheetlist=[]
# Start Transaction
for a in elt:
views=[]
if IN[2] == 1:
v=AssemblyViewUtils.Create3DOrthographic(doc,a)
views.append(v)
if IN[3] == 1:
ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
views.append(ds2)
if IN[4] == 1:
ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
views.append(ds3)
if IN[5] == 1:
ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
views.append(ds4)
if IN[6] == 1:
ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
views.append(ds5)
if IN[7] == 1:
ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
views.append(ds6)
if IN[8] == 1:
ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
views.append(ds7)
if IN[9] == 1:
ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
views.append(ds8)
if IN[10] == 1:
ds9=AssemblyViewUtils.CreatePartList(doc,a)
views.append(ds9)
if IN[11] == 1:
ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
views.append(ds10)
if IN[12] == 1:
ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
views.append(ds11)
viewlist.append(views)
if IN[13] == 1:
sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
for v in views:
if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
sheetlist.append(sh)
doc.Regenerate()
# End Transaction
OUT=viewlist,sheetlist
hey! how did you get this to work? im really struggling
make sure the input for assembly is AssemblyInstance element
can you share the snip, i am using 2022, script run completed but output is null.
