Hello!
I am trying to create a rebar along a curved beam. I know how to create curves for curved faces and then create the rebar from those curves but the problem comes when I try to create a rebar perpendicular to the side faces.
There come some results through the search tool that could help you to get started:
https://forum.dynamobim.com/search?q=rebar%20curved%20beam
See also related packages and what comes up when typing “dynamo rebar” in Google, and if possible, come back with a screenshot of what you tried clearly indicating where we can help you
See this for instance:
http://core.thorntontomasetti.com/dynamo-for-rebar/
Hello again,
I attach a screenshot that clarifies better what a I am looking for. The thing is that I know how to create a rebar tht follows one face, so I created the longitudinal rebar that goes on the wall face as you see on the picture. But I do not how to create a script to make that the U- rebar (highlighted on the image) follows the curvature of the beam.
I have tried to search on youtube or following some examples at https://revitbeyondbim.wordpress.com/ in which he does somehting similar but I cant find the script anywhere. Thanks to anyone could help me out with it.
This document could help to find how to start:
http://aucache.autodesk.com/au2016/sessionsFiles/15357/11251/handout_15357_ES15357-VERMEULEN-AU2016.pdf
Awesome! This document is what I was looking for, this is going to be very helpful.
Thank you so much.
Manuel Colio
Great, if you do not plan to show your graph here, please mark that this post solves the problem. Thanks
Hello @manu.
Have you ever solved this problem?
Could you share it please?
Thanks.
it not found, can’t access the link
