I am trying to get information out from a fabrication rectangular elbow for the inner radius and create a parameter to make a label. I can see the values in a lists however I do not know how to get the information from the list to a shared parameter. Any help will be appreciated.
The inner radius parameter does not exist on a fabrication. ITM radius elbow part. Though dynamo I am able to find the parts dimensions and inner radius but cannot figure out how to get the data from a list to export out to a new shared parameter.
Thanks for the help. Attached is the screenshot of the working one. Now I have no idea why it works but it does. Now I am trying to get the Top Extension to work.
You might check if the parameter and the value are the same StorageType, for instance,
if you set a string-value into a number-parameter, you will get an error.
I can’t see any error boxes but what I wrote above could be why you still are running into some kind of problems.
The one with the code block “Fab_Inner Radius” seem to have just gotten lucky. What it does is pulls the last value in the fitting instead of one that I actually want. So now I need to figure out a way to have the parameter filled by a specific dimension from the fitting from a list. So when I run the routine on a straight piece of duct the Fab_Inner Radius parameter gets filled in from the length of the piece of duct since that is the last dimension. Let me know if you have any tips on how this could be accomplished.
I have done a dynamo script that works for the inner radius however you need to have a shared parameter in the project for it to work. The script will write the inner radius of a fabrication bend into your shared parameter which you then then use in schedules
