Hi All,
I need your help. I want to create a Profile from the polyline.
Thanks!!!
Hi @lebinhx3c2012,
You can use the Civil 3D Toolkit. Here’s a simple example using a polyline with no arc segments. If you need that functionality you’ll have to add quite a bit more logic, but it is possible.
ProfileFromPolyline.dwg (1.1 MB)
ProfileFromPolyline.dyn (68.3 KB)
Hi @mzjensen
Thank you very much!
Hi @zachri.jensen ,
I’m Create Profile from Polyline, but at the break polyline of the profile it doesn’t follow the polyline.
That’s because a profile can’t have two different elevation values at the same station.
Thank @zachri.jensen ,
Do you have a solution for this situation?
It’s probably easiest to just move one of the polyline vertices a very small distance so that the two aren’t equal.
