Copying rebar from beam to to another beam
Hi everyone,
I’m using the script posted by @Einar_Raknes in this discussion Copy rebar from one element to another: to copy rebars from one beam to another, but it works only if I change the entry IN[0] coming from the node List.FilterByBoolMask to “out” and it copies only the top rebar set in the beam?
In addition, I can’t figure out why the comaparison between the same beam’s instance in the ListEqual is false ??
Please check my references below:
Rebar.Copy.dyn (17.4 KB)
beam_test.rvt (3.4 MB)
Thanks.
Change the lacing on this node to “Longest”
I had a seperate issue when testing your script, and that was an issue with the BIM4Struc Custom node having an invalid input.
I Extracted the python from it and change the graph as shown below and it worked for me.
Example project.
@pyXam
Thanks for your reply, I changed the lacing to longest and it works fine!! (I did not understand why changing lacing to longest in this case?)
Thanks.
Here is a nice read on lists which includes some explanation on lacing.
https://primer.dynamobim.org/06_Designing-with-Lists/6-1_whats-a-list.html
