Hello ,
i have a Revit file that contains views and inside it a linked revit file that have the same views but are also placed on sheets. is there a way to copy the sheets from that linked file so that it appears as in the linked file with the views placed on them ?
as an example i have two Revit files the file called (ABC.rvt)has the views but not any sheet the second file called (ABC_withsheets.rvt) has the same views in addition to a sheet where this section is placed on , and i want in the the file ABC.rvt that i have the same sheet with this section placed on in the same place, is that possible please ?
ABC.rvt (5.7 MB)
ABC_with_sheets.rvt (2.7 MB)
i would appreciate any help.Thank you
