Copy keynote value to another parameter
Hey.
As the headline say’s.
Can i copy the keynote number, to another type parameter, using dynamo.
Nichlas
Yes, this is just a Parameter value. Use Element.GetParameterByName and Element.SetParameterByName nodes to do this.
I can’t get it to work, will you show me. :slight_smile:
Here is general way to do this. I just selected two random elements from a model for demo.
Hey.
I can’t get it to work, why does my method not work??
Udklip
Did you see the Element.Type node? The Keynote is a Family Type Parameter, not an Instance parameter. You have to get the Type first, then get the Value.
Arrhh Sorry.
Now it work. :slight_smile:
Hi, can this work the other way by copying a type parameter and pasting it in to the keynote field - If this matches the keynote .txt file will it pull the keynote value / text?
