Copy from a linked file as a void generic model
Hello
I’m trying to create a script that would copy all elements of a category from a linked model to the current one. the twist is the copied elements should be void generic models.
the first part (copying part) is done using bimorph nodes.
is there a way to change the copied element as stated? or is there a node that copies the elements as generic model?
Hi @ hre is an exemple where i copy linkelement and change the categori for family element from furniture to generic and set it as a void…
Revit_lD6ftNLQTG
rhythm and genius loci
THANK YOU, could you tell me what is the rhythem package version you are using?
i cant find the nodes you are using!
