Copy Selected Elements from Linked
Hi guys, I try to copy selected linked elements into my current project, however nothing is copied. Is there a workaround. I’ve tried using both Springs’ and Rhythm’s nodes.
Thanks in advance!
EDIT:
The first error is:
Warning: Documents.CopyElementsFromDocument operation failed.
Cannot copy element.
Parameter name: elementsToCopy
while the second:
Warning: One or more of the input types are not matching. Couldn’t find a version of CopyElementsFromLinkedDocument that takes arguments of type (Autodesk.Revit.DB.Document,System.Object,__array)
Hi @judithdwilliamsG5VAE
Do this-> SelectModelElement node -> Select Revit Link Element -> Connect to LinkInstance/SourceElement.
Good Luck!
