you are the man sovitek thank you alotttttt, works perfectly
hello @sovitek , i was trying the script and when there is more than a window or more than wall it doesnt work as expected , is there a way to fix that. i dont want to ask you a lot of things you already really helped me a lot , i would be grateful if you tell me is there is a way or not or what is the way ? and i will try to figure it out , because i am new to dynamo and dont know what is it exactly capable of doing
Hi @sabra.tarek yes its possible…just try modify the graph so it could work there as well…try play around with it [good exercise] and if you go totally stuck…then just let us know and we can try help ![]()
Thank you sovitek , i have a problem with assiging the tags to the windows, i cannot find out which tag belongs to which window because i cannot get the element ID of the host elements for the tags, i thought about maybe assiging them by distance ? the tag that is closer to the object belongs to it,or is this wrong?
allright…can you share these rvt files…and we can take a look
Hi @sabra.tarek something here should work in that case…
forumHome.dyn (84.9 KB)
